SOURCE: Sony DSC T-5 Cybershot
I called Sony, did what they said, and now my camera is working just fine...no more blurry pics. Go to menu, click arrow right, click arrow down 3x till you get to "Setup 1," click arrow right scroll down to "Initialize," click to right, select OK, press center button. This initialized everything back to default settings and now I don't have blurry pictures anymore.
SOURCE: Sony Cybershot DSC-H7 - can not change flash settings
for anyone who wants to know how i solved my problem with the flash saying it cannot be changed...
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
SOURCE: manual and software cd for sony cybershot dsc-t700
Hi
Please download the user manual for your Sony Cybershot DSC-T700 from this link
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/DSC-T700-_E
The drivers for your camera could be downloaded from here. Need to select your OS from the pull down menu before downloading
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCT700
That is all you need to connect your camera to your PC.
If you would like to edit your pictures, you need to buy that software
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at [email protected]
I work in a Sony service center.
Tom
SOURCE: SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
