Garden Logo
J
John duim Posted on May 20, 2018
Starter cord replacement of EF 1000IS Generator
Have to replace recoil rope for Yamaha EF 1000 IS generator
Putting new pull rope on my 4500 champion 4500 generator
The recoil starter can usually be unbolted from the engine for service. If you can retrieve the end of the broken rope, and you know how long the new rope should be, you can tape or stitch the new rope to the end of the old rope, then pull on the knotted end of the old rope to pull it out of the starter and draw the new one in. If this won't work (the old rope may be too rotted to hold together, or the pull force to wind the rope around in the starter is too much), you'll have to take the starter apart. This is nasty because you have to get the spring properly engaged with the frame and the starter plate when you put it back together, and there may be an element of personal hazard if there is tension on the spring. You may want to have the starter plate on the bottom when you lift off the cover, hopefully this will prevent everything from spilling out before you get a chance to see how it goes together. Wear safety glasses and leather gloves. Wearing a padded jacket or heavy-duty shop apron may also be a good idea.
Check whether the handle on the new rope requires the rope to be fed through its opening in the starter, and be sure it goes it is wound in the same direction as the original rope. Also, you want just enough tension on the spring to hold the rope handle up against the starter without flopping around, but not so much that the spring winds up too tight before you get to the stop with the rope pulled all the way out.
You may wish to take the starter unit to a small engine shop and pay them to wind on a new rope. :)
These are the considerations I've observed when looking over recoil starters - someone may have more detailed information on your model.
Finally, evaluate the storage conditions for the generator. A good rope should last a long time; perhaps excessive humidity, chemical fumes or exposure to UV radiation rotted out the rope. Did you put oil in the cylinder per the long-term storage instructions (Page 14 of the manual)? If not, that could result in excessive pull force. You may be able to free up the generator by removing the spark plug, putting a small amount of lightweight oil, turning over the generator using the starter spline shaft (be careful not to damage the shaft with tools, and observe which direction it's supposed to rotate when the recoil starter lets go), Change the oil if you have to use something lighter than recommended to get sticky parts loosened.
Here's a link for the manual (Page 14 is actually page 17 in the PDF viewer):
http://www.championpowerequipment.com/media/4663/100216_manual-english_12-10-16.pdf
1helpful
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 • Garden
How to change recoil rope
How To Replace The Starter Rope On Your Recoil ...
? 4:47
www.youtube.com/watch?v=Q3NjVomUQJM
Feb 25, 2009 - Uploaded by craig1974 Me showing you how to replace your starter rope on your recoilassemblies.
2helpful
How do I replace broken starter rope
I cannot see it obviously. Clear the are from its cover and recoil another rope to the crank winding. Keep in mind to put the crank wheel under its spring tension before attaching the new rope.
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
1helpful
I need to rewind a rope on pull start powermate generator
This requires a bit of strength in the hands and the recoil will have a fair amount of tension behind it. Best have a small engine service center look at. Not expensive
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
