Crafts & Hobbies Logo
ROB38 TAID Posted on Mar 22, 2018
How to replace the blade on an KW713 plane - Crafts & Hobbies
Porl K Smith
Level 1:
Habit-Forming:
New Friend:
  • Contributor 12 Answers
  • Posted on Oct 22, 2019
Porl K Smith
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
12
Questions
Helped
2159
Points
30
Loosen the screws on the clamp holding the blade and slide the blade out sideways using an offcut of timber. If the mahine has been abused or neglected, the blade may be in pieces. Reverse operation to mount new blade. Oftentimes the is deformation of the and that may have to be replaced also.
Fits the driver belt of a B&D planer model KW713/715 in a BD713?
Cannot guiarante it but it seesm like it should.
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
I'm looking for replacement blades for black&decker plane mod 21286 or part # 7696,i need set of bldes
Any Internet search will yeild sources. You may find that HSS blades are more $ than carbide ones, IMO because the carbide are old-stock and have not be repriced.
But first make sure you need replacement blades. Initially because the blades are reversable, and 2nd, either the adjusting height control is not functioning OR, and was in my case, the lower plate with 2 screws has slipped inwards. Since I believe the blades slide out after the top plate (3 screws) is removed, do NOT move the lower plates
1helpful
Source for stanley plane parts specifically, the knurled set screws that hold the side plate in place on a Stanley #140 skew blade plane
hello. you can order direct from Stanley at http://www.stanleytoolparts.com/planes.html
Enjoy your woodworking. Regards, a fellow woodworker, Joe
PS please rate my answer. thank you.
Jan 07, 2010 • Hand Tools
Ceiling fan
Hello Capt Treb. Turn off the power. Check all the blade and support arm mounting screws for tightness. Stand on a step stole and view the blades from a horzinal plane to check all blades have the same pitch by slowing rotating by hand. You may have to bend the arms a little to aquire an equal on the plane. To locate a weight balance is a shoot & miss with the balance weights. Good luck.
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
