SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
SOURCE: AEG Lavamat 518 manual
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
