Washing Machines Logo
M
Maargaret Clancy Posted on Jan 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I choose a cycle on my Bosch logicxx 7 washing machine and press the on button, it just bleeps twice & nothing else happens
Gerry Harvey
Level 3:
Genius:
  • Bosch Master 1,482 Answers
  • Posted on Jan 01, 2018
Gerry Harvey
Bosch Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378858
Points
4533
Could be error due to door not closed / door interlock fault check at time if door is locked as it should be before machine starts and stays locked for further 3 mins after shutdown.
5 Related Answers
Anonymous
  • Posted on Apr 17, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Anonymous
  • Posted on May 11, 2008
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Anonymous
  • Posted on Jul 16, 2008
SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Anonymous
  • 530 Answers
  • Posted on Jan 06, 2009
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Anonymous
  • Posted on Jan 07, 2010
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
I have a Bosch SHU9902UC/U06 Dishwasher that won't start.
No water getting in check water inlet pipe is not twisted or turned off eric992
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
1helpful
F14 fault on Bosch Maxx 7 I have low water power, could this be the problem? Machine bleeped at me then stopped. I have turned my machine off, but the washing cycle had not finished.
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
3helpful
3answers
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Bosch classic 1200 key sign showing and just bleeps wont start wash
To start a cycle when the child lock has been activated you have to keep the start button pressed for a least 5 secs. Check your user manual for deactivation of child lock.
If you don't have the manual, use the link to download a copy, you will need the Enr number from the sticker on the inner door.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
2helpful
Where is a cancel or clear button? I have the button pressed for regular wash and then I hit start, I then realized I wanted to do quick wash instead but I cant find the cancel or clear button.
Welcome to FixYa.
If your machine is indeed an SHU66 series machine it should resemble the image here, with perhaps a different color...
If you notice the two buttons pressed together should cancel the cycle and force a drain/end cycle.
For future reference, if you'd like to simply select another cycle after one has already been started, press the button applicable twice quickly and it will switch to that cycle.
Hope this answers your question. Let me know if your require further assistance.
Thanks for choosing FixYa, good luck.
Regards,
Macmarkus :)
When i turn it on it bleeps and f 37 comes on
u have a fault the operation of the washer.
The machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
42helpful
2answers
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
