SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
[email protected]
pallesappliancerepairs.com
SOURCE: Hotpoint - WML520 washing machine - Not pumping water
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You could have a blockage in the sump filter or there may be
a foreign object in the pump housing stopping it from working, there may be a
faulty or lose wiring connection on the pump. Is the tub still full of water? If
yes then try lowering the outlet hose into a bowl or bucket and see if any
water comes out, if yes the system is clear and it would be pump related, if no
then you have a blockage somewhere.
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal
0
false
false
false
font-size:10.0pt;
For Hotpoint, Creda and Indesit error code definitions
use this link. This will give you some idea as to where the fault may be.
