Washing Machines Logo
My washing AEG machine & tumble dryer both doesn't work with EHO codes which means main supply is unstable. What will I do? I need help. Please. Thanks, Mila from Quezon City
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jul 08, 2008
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Anonymous
  • Posted on Aug 03, 2008
SOURCE: AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
rafiqahmad
  • Posted on Dec 01, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Anonymous
  • 44 Answers
  • Posted on Mar 21, 2009
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mukesh Kumar
  • 3230 Answers
  • Posted on May 06, 2009
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
What is EHO code in a w AEG washing machine ?
There is a problem with the power supply on the main board.
My aeg washing machine is showing eho
Power supply problem. Try another plug in. If it still doesnt work you have a wiring problem.
What does it mean code EHO on a frontloader aeg brand
This causes a water leakage, which flows inside the bottom of appliance, thus switching on the Aqua Control sensor and generating alarm EF0/EF3.
Be sure to find water leaks and repair the defect.
Incline the washing machine of about 10 cm to spill the water, so that the sensor can operate normally again.
Dado
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
4helpful
What does error code EHO mean
That error code does not exist,the closest is EH1.which means that the supply to the machine is incorrect.What is the model,and PNC.number,hope this helps.
Regards.
11helpful
Hi
regards
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
