SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
SOURCE: aeg lavamat 64840 keeps draining even when it is
There are variables but the quickest check with minimum equiptment, i would locate the pressure switch then pull the small clear pipe off that is attatched to it. Firstly , blow into the pipe and see if it isnt possibly blocked.(If it is blocked, the control will see the system as over full and all that will happen is the pump will continue to activate). Before you put the pipe back on the pressure switch, activate the washer for a few seconds and see if the cycle wants to start normally. If so, switch off and reattatch the pipe and do a wash test.
SOURCE: On my AEG Lavamat 62810 washing machine, when I
inside the waasher there is a fill level valve i think its blocked up with "gunk" if you look inside the washer you should see a small pipe from the bottom of the drum going up to a round type of valve with lots of wires fitted to it at the top of the washer,,,pull the pipe off this valve and "blow hard" down through it,,any "gunk" should be pushed out and the washer should wook ok after that,,,if it dont change the valve!!!
Testimonial: "Yes! The machine now seems to be working fine after what was a fairly straightforward job even for a semi-klutz with machinery like me. Many thanks."
SOURCE: AEG OKO Lavamat 6150 Intermittently the
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
SOURCE: AEG oko lavamat 74500 not
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
John C
