This is a tahoe diesel generator the oil is fine
Ask your supplier to get more details. They is the OEM supplier of the diesel engine, so they can contact the diesel engine supplier. If you plan to purchase diesel generator set, please visit at https://starlightgenerator.en.made-in-china.com
SOURCE: 2000 ford f250 super duty 4x4 7.3L diesel oil leak
The HPOP (high pressure oil pump) is right under the filter housing. There are 2 lines that distribute the oil to the cylinder heads. The o-rings on those fittings go out. Kit is available from Ford or International. You will need a special wrench to get to the fittings though.
SOURCE: 05 F-250, 6.0 Diesel, fuel filter
There are 2 fuel filters. One on the engine to the right of the oil filter. The other one is on the left frame rail . I hope this helps
The oil pump may not be working or the pressure sender may be bad.
