Toro Lawn Mower With Toro Power Tools Logo
D
Denny DeGrand Posted on Jul 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Toro SW5000 zero turn will not turn :
The right rear wheel does not turn properly thus not allowing it to drive straight or turn to the left.
Ron Stone
Level 2:
Sergeant:
  • Expert 408 Answers
  • Posted on Nov 02, 2018
Ron Stone
Expert
Level 2:
Sergeant:
Answers
408
Questions
0
Helped
112346
Points
562
Make sure your tires are at proper pressure first. then you can google how to adjust the drive linkage.
5 Related Answers
Anonymous
  • 226 Answers
  • Posted on Jan 07, 2009
SOURCE: Left rear wheel wobbles
put on your spare doughnut tire and see if it's bent to .. if it is then you bent the axle not the rim.
Anonymous
  • Posted on Mar 30, 2009
SOURCE: Rear end in 1999 chevy 1500 binds on turns
well i had the same problem everyone told me the clutches in the rearend were sticking making it stick in positive traction (only your passanger side rear wheel pulls unless you start spinning then a type of clutch engages the other side so you have traction then when you stop spinning it disengages it should never be engaged if your on pavment) now you can do what i did listen to everyone when they tell you its normal or you can take it to someone with experience now and save yourself some money cause it will start popping then it will get some viberation then next it will break the clutches and when that happens you will have to replace the pinion,ring,and the spider gears as well as the clutches.make sure you have pleanty oil in rearend if you dont add the limited slip conditioner it might free clutches up but if i had it to do over id put it in the shop or stop driving it before i broke something hope this helped
Anonymous
  • 224 Answers
  • Posted on Sep 26, 2009
SOURCE: 2004 Aveo roaring noise from front and rear wheels that
wheel bearing or cv joint . remove brake caleber remove spindel nut outer bearing comes out easy inter bearing is is a little harder
Stephen McGuinness
  • 143 Answers
  • Posted on May 20, 2010
SOURCE: my toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
Anonymous
  • 10 Answers
  • Posted on Oct 04, 2010
SOURCE: My car makes a loud
Possible. If you have changed tires lately, make sure they put the right size tires on. If they went up in size by any measure, it could be rubbing on the tire well and thus making the noise. Check the users manual if you have it and check to make sure the tire sizes are correct. Also check your power steering fluid. That would make a humming or moaning noise but it would be noticeable while turning.
1helpful
I have a toro 3150Q greens mower When turning tight right the wheel on the right stops and goes into a neutral position. When turning tight left the wheel on the left wants to keep driving. Help?
I would suspect the right wheel motor is barely working (or not at all) and forward motion is from the left only so any attempt to turn left is problematic since the right wheel motor has little or no power. If you can get all wheels off the ground you can test and compare wheel motors.
May 02, 2019 • Toro Garden
2answers
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
1helpful
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
This ZR4625 is new. It will not track straight. With both levers forward it tracks to the left, I can pull back on the right lever and it tracks ok but it slows down a little. What do you adjust?
First check both rear tyre pressures, if ok you need to adjust the rod that runs between the left lever and the hydrostatic drive on the left rear wheel so that the short lever on the hydrostatic drive travels further when push the drive lever forward. Regards Phil
Rear on a2004 astro van awd v-6 locks up when making turn's left or right.but does'nt do it when gowing forward or reverse.
Rear end is a lockup dif. This couples both wheels.It has clutches that allow inner and outer weels to turn at different speeds when going around corner, thus eliminating most tire scrub. If noise is coming from dif. change dif oil and redress clutches.Driving in a straight line with a lockup dif. would not normally be noticed,because both rear wheels are travelling at the same speed.
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 • Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
