If you replace the carburetor needle seat and bowl gasket it will do the trick. Look up your model snowblower at www.arcolawn.com and you can have them shipped.
Good luck
joe
Remove bottom cover(4bolts) 3/8"Remove plastic housing cover (mine had 2 bolts)3/8"Loosen belt guide bolt.1/2" rotate guide away from belt.I used a pipe wrench to hold main shaft and removed drive pulley.Replace drive belt as you return pulley onto shaft.Replace auger belt.Align belt guidesSet handle adjustmentsReplace coversTest and hope for warm weather, I live in BuffaloHope this helps
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
