Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Logo
M
MIKE MCGILL Posted on Dec 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Putting new gas line on as I have had lots of trouble with gas leaks. anyway gasket fell off of carb. can you send a pic of how it goes on? the gasket that is
I put it on the way it looks like it would but gas keeps dripping out of the carb. This is a Sigma 6500E gas generator.
Generator Guru Parts
Level 3:
Master:
  • Master 286 Answers
  • Posted on Dec 20, 2016
Master
Level 3:
Master:
Answers
286
Questions
Helped
148858
Points
1274
Mike,
Sorry to hear the carb is leaking. This happens when the Carb Float Needle gets stuck and is easy to rectify.
If you watch this video on YouTube it will show you how to free up the Float Needle. It is the same procedure on all Carbs:
https://www.youtube.com/watch?v=7LrBmeBcVnA
I have a ryobi leaf blower that is leaking gas. It seems to be coming from the carb. The leak started when I changed the fuel lines. I then cleaned out the carburetor. It ran fine for one day and now the...
It sounds like maybe you tore the gasket that attaches the carb to the block. Check that, Also make sure your screws holding the carb. in place are tightened.
MODEL # 12AVB29Q711 I NEED TO KNOW THE ALL THE GASKETS LINE UP INCLUDING METAL SPACER FROM CARBURETOR TO INTAKE THEY FELL OUT NOW NOT SURE WHAT GOES WHERE.
you havent said what engine you want the gaskets for!! the serial number is fo the machine only. Im guessing that it has a honda gcv135/160 so i have attached pics of the carb and gaskets and the order the go in. make sure you get number 15 the right way round or you will block up air transfer holes!!!
Gas leak when I put the scooter on the kickstand
I own an Andretti M50 and I had 2 different gas leak problems, and neither was a stuck float.
- the gas filter that comes with the bike is a 2-piece screw together unit and the gasket between the 2 pieces leaks gas down onto the cylinder!
I replaced with a $3 one piece from Pep Boys.
- the second leak the gas just poured onto the ground. It was caused by poor design and tight tolerances where the fuel line attaches to the carb. The fuel line would get guillitoned every time you hit a bump by the engine swinging the carb tight against the frame. I rotated the carb in its manifold away from the frame. (you have to cut the nubs off the carb manifold to rotate it).
Runs in idole, but boggs down and quit when i give it gas....(double edge echo hedgetrimmer 1500 gas power
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 03, 2009 • Echo Garden
1helpful
Give it gas slows down
1) spark plug
Chain Saws:
Remove Carburetor
Yard machine ym26ss straight shaft trimmer. New gas,
1) spark plug
Chain Saws:
Remove Carburetor
Riding mower backfired; now leaking gas.
Carb gasket will most likely need to be replaced. Good idea to pull apart, clean and soak carb and floats anyways in the process.
Nov 08, 2009 • Garden
8helpful
2answers
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ [email protected] and i will point them out
11helpful
2answers
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 • Garden
Top Sigma Powers Inc Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sigma Powers Inc Electrical Supply Expert? Answer questions, earn points and help others
