LG 50" 5400 Series LED HDTV - 50LN5400 Logo
A
Anonymous Posted on Jun 26, 2016
Have LG 50LN5400. Has audio and using flashlight, screen shows images
I replaced 1 strip of leds for backlight, all 3 boards but when powered on, backlight flashes once and goes out. I upgraded the tv software to prevent this after installing the new leds. what am I missing?
Ravi
Level 3:
  • LG Master 1,682 Answers
  • Posted on Jun 27, 2016
Ravi
LG Master
Level 3:
Answers
1682
Questions
Helped
579963
Points
8910
Before backlight, I would always suspect TCON board
  • George Smith Jun 27, 2016
    Unfortunately, I have already replaced all 3 boards(psu, main and TCON). Only board not replaced is the one connected to leds. Unable to source that one.
2answers
LG 47LN5750 Have audio and have done flashlight test - I can see image with flashlight - no backlights.
Make sure the power supply is being triggered. If there is no LED_On signal it may read that. But if you know the backlight should be in, then check LEDs. Try powering each LED on the strip individually with a battery/resistor. unhook each strip before testing.
How do I determine if the problem with my LG TV is the LED power supply or the actual LED strips if when powered on, they flash and go black and the FlashLight test shows darkened images on the Screen
Chances are if it briefly comes on the backlights I mean the power board is shutting off because of over voltage or over current and some lamps are bad...On this set of yours if you try to test the strips you need to take into consideration these are 6 volt lamps not 3 volt that are used on most sets.
1helpful
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
1helpful
LG LED TV, model #50LB5900-UV has flickering screen. Need advice on part replacements.
It is a very common problem for LG LED TV, the problem is defective back lights LED strip. You need to open the display panel, find the burn out strips & replace it (them).
1helpful
Black screen, audio, no backlight. What's wrong?
This is most likely a failure of the actual LED strips themselves. They do attach to a board at the edge, it could be the board but you have to order the board and strips as one unit.
http://www.shopjimmy.com/lg-lc420dug-jfr1-led-strips-10-strips-1-board.htm
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
I have no light on my led tv
The most likely problem is the Backlight Inverter. It supplies the power to the LED array which illuminates the screen. If you are brave and also technically able, it can be replaced at home. Here is a video to help. LCD TV Repair Tutorial How to Replace the Backlight Inverter Board in LG...
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
