Will not clear code until I unplug. Plug back in, will then drain out. then I run a drain and spin to finish. I run a clean cycle and I am able to wash two to three more loads until it codes agin.
SOURCE: Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
SOURCE: F1 error code on Kenmore Oasis He
After getting the F1 error on my model 110.27086601 and looking at other posts here & elsewhere, I made one call to the "Product Resolution Center" at 800-847-9083 on 4/9/10. They answered quickly, looked up the model & serial number I gave them (begins with CT18) and confirmed that the unit is covered under the "upgrade plan" (as opposed to calling it a recall). They are sending the part directly to me today and they scheduled a Sears tech to come install it in 10 days (or less if the part arrives sooner). The part, shipping and service call are free. The whole call took less than 5 minutes and was no more difficult than ordering a pizza. The agent was polite, professional and a pleasure to deal with.
I'm pleased that 2 years after the warranty expired they are providing this repair free of charge and without any hassle.
To those who have had problems when calling or who will be calling, may I offer this tidbit for dealing with any customer service contact? Be polite and businesslike. The agent on the other end doesn't need to hear about "how disappointed you are, blah, blah" or that you've "been a loyal customer for 84 years" and you've "never had a problem like this" or any other editorial commentary - just be friendly, and say something like " Hi, I have an Oasis washer with the F1 problem and I understand that there's a recall covering this." That's exactly what I said and the agent efficiently handled everything from there.
Remember, the agent gets measured on the number of calls they complete so they just want to take care of you as quickly as possible. Help them by just simply stating the problem and just answering their questions with just the information requested. They are not there to listen to people whine - they've heard everything you have to say a thousand times and they will appreciate your brevity and no nonsense demeanor. Make it easy for them and they'll make it easy for you. Do your venting here if you must.
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
F21 Fault Code Repair LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
