Luggage & Travel Logo
A
Anonymous Posted on Mar 24, 2016
Carry on luggage handlebar does not open fully. it opens only half and not more.
Donna Herrera
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 15, 2018
Donna Herrera
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
447
Points
30
So, your Carry on luggage handlebar is not working properly! Well, if you want then there are many online sites also available like sweethome where you can easily get the best carry on luggage at a price which will fit your budget easily. They have the best quality and modern bags which will add a touch of luxury to your personality.
Donald Ayers-Marsh
Level 3:
  • Master 1,389 Answers
  • Posted on Mar 24, 2016
Donald Ayers-Marsh
Master
Level 3:
Answers
1389
Questions
0
Helped
559460
Points
6679
Check manufacturer website for instructions, online help/chat, or a support phone number.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
2003 town car trunk wont open with remote or button on door, only key?
Luggage Compartment Lid
The luggage compartment lid module receives a voltage signal from the driver door module (DDM) when either the button on the driver door trim panel, the keyless entry keypad, or the transmitter is pressed (twice on the transmitter). Voltage is then supplied to the luggage compartment lid latch, opening it. Using the luggage compartment lid key operates the latch mechanically, resulting in manual-only operation of the lid. There are two switches in the latch. One is monitored by the luggage compartment lid module to sense if the latch is closed. The other switch in the latch is monitored by both modules (LCM and luggage compartment lid module) and is used for disabling the anti-theft system, which is contained within the LCM. The luggage compartment lid module powers the lid motor to move the lid to the full-open position when it senses the latch has been opened. Optical sensors within the lid motor are monitored by the module to determine when to turn off power and which circuits should be powered or grounded to the lid motor. When one of the buttons is depressed with the lid open, the DDM sends a signal to the luggage compartment lid module which powers and grounds the correct circuits to the lid motor and lowers the lid until the latch closes. The module senses the latch closing through the lid latch switch that is monitored. At this time, the module powers the closing motor, slowly pulling the lid to a fully closed position. Two switches within the closing motor are monitored by the module to determine when the closing motor is fully down or up. The module has a vehicle speed output (VSO) (circuit 679) signal that is used to shut down the system if there is a VSO of approximately 5 kph (3 mph) or more. For diagnostics, the module uses the ISO-9141 circuit 70 that is included in the DLC (data link connector). Whenever battery power is lost to the luggage compartment lid module, luggage compartment lid motor or the luggage compartment lid closing motor; the system must be initialized.
NOTE: The luggage compartment lid motor is equipped with an optical sensor that the module uses to determine if the lid is closing on foreign materials based on lid speed. If the module detects this occurring, power and ground will be reversed to the lid motor and the lid will open.
  1. Verify the customer concern by operating the luggage compartment lid using the four different methods (driver door trim panel button, transmitter button, keyless entry keypad and key) to duplicate the concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Luggage compartment lid motor
  • Luggage compartment lid closing motor
  • Luggage compartment lid latch
  • Luggage compartment lid and hinges
  • Battery junction box (BJB) fuse(s):
    • 109 (40A)
    • 1 (30A)
  • Central junction box (CJB) fuse(s):
    • 30 (7.5A)
    • 14 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step. Verify the two grounds (G204, G401) are clean, tight and free from corrosion. Remove and clean to make sure.
  1. Monitoring the PIDS in the luggage compartment lid module can verify the DDM is sending the lid-open signal to the lid module. They can also be used to determine if the latch switches, the lid switches and the lid motor sensors are all providing the luggage compartment lid module with the correct and necessary information to operate the system. The VSO input can shut the system down if there is a signal indicating 5 kph (3 mph) or more.
  1. If the electrical lid operation is ok, but the key is ineffective, refer to Section 501-14 .
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) located under the instrument panel and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
    • If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the DATA LINK DIAGNOSTIC TEST. If the diagnostic tool responds with:
    • CKT 914, CKT 915 or CKT 70 = ALL ECUs NO RESP/NOT EQUIP, refer to Section 418-00 .
    • NO RESP/NOT EQUIP for luggage compartment lid module, Go To Pinpoint Test A .
    • SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the luggage compartment lid module.
  1. If the DTCs retrieved are related to the concern, go to the luggage compartment lid module Diagnostic Trouble Code (DTC) Index to continue diagnostics. For lighting control module (LCM) concerns, refer to Section 419-10 for a complete DTC index.
  1. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart. Luggage Compartment Lid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Defective Luggage compartment lid module INSTALL a new luggage compartment lid module. B1359 Input Low When Key in RUN/START Position Luggage compartment lid module Go To Pinpoint Test A . B1551 Latch/Lid Release Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2418 Sensor Power Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2419 Sensor 1 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2420 Sensor 2 Invalid Luggage compartment lid module Go To Pinpoint Test B . B2421 Vehicle Speed Sensor Circuit Failure Luggage compartment lid module Go To Pinpoint Test C . B2522 Vbatt 1 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2552 Vbatt 2 Open Luggage compartment lid module Go To Pinpoint Test A . B2698 Vbatt 2 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A . B2703 OPEN CLOSE SW Input Stuck Active Luggage compartment lid module Go To Pinpoint Test B . B2718 Lid Ajar Output - Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2721 Lid Ajar Output Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . B2748 Drive Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test B . B2755 Drive Motor Short to Battery Luggage compartment lid module Go To Pinpoint Test B . B2757 Drive Motor Output Short to Ground Luggage compartment lid module Go To Pinpoint Test B . B2825 Obstacle Detection Path of Decklid Luggage compartment lid module Go To Pinpoint Test B . B2876 Striker Drive Short to Battery Luggage compartment lid module Go To Pinpoint Test D . B2877 Striker Drive Output Short to Ground Luggage compartment lid module Go To Pinpoint Test D . B2905 Striker Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test D . B2906 Striker Up SW Input Invalid Luggage compartment lid module Go To Pinpoint Test D . B2907 Striker Down SW Invalid Luggage compartment lid module Go To Pinpoint Test D . B2908 Latch SW Input Invalid Luggage compartment lid module Go To Pinpoint Test B . B2910 Striker Up SW/Striker Down SW Mismatch Luggage compartment lid module Go To Pinpoint Test D . B5131 Clutch Circuit Failure Luggage compartment lid module Go To Pinpoint Test B . C1123 Vehicle Speed Sensor Circuit - Fault Luggage compartment lid module Go To Pinpoint Test C . Do you know what diagnostic trouble code's are ? That would be the first place to start , checking for code's . An seeing how you probably don't have a ford IDS - scanner . your best bet mite be to take it to a qualified ford - lincoln dealer
2answers
Is first bag free
To both questions, "It depends on the airline."
While there are standard baggage sizes across some of the major carriers, it is prudent to check the airline you will be traveling upon regarding luggage fees, size allowances, and just what can be carried on and what must be checked. Plus, you have to know what you may carry in carryon luggage, what you can not take, and what can not be carried in checkin luggage. And weight is a factor as well.
2answers
Can aerosol container be taken either carry on or checked luggage
look at your airlines carry rules-- mine wont allow in carry on OR checked luggage
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
2helpful
Luggage lock open
I try to reset the lock on my luggage and I block it is only one pin locks and the other one is stuck inside
Luggage number lock
I have forgotten the number lock code on my hard shell equator suitcase and can't get it opened. how do I rectify this.
1helpful
2answers
Do I need to buy a luggage scales? My luggage overweight frequently.
It is often you may carry a lot of things in your luggage and thus when you are checking in at the airport, you have to weigh your luggage. If the luggage is overweight then one has to pay some extra money for it. So it is advisable that you would better buy luggage scales and weigh your baggage before going to the airport. This can help people save a lot of money and also help you in carrying the baggage easily.
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Top Luggage & Travel Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
