James , sounds like a plugged catalytic converter, the test I use for this is buy cutting exhaust pipe in front of converter, noticeable change in engine performance will be had if converter was plugged.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Testimonial: "even if i have good flow out of the tail pipe"
I have good exhaust flow out of the tail pipe is this normal for a pluged cat. and would that read a code
James, I am not sure what you call good flow, If flow is indeed good, may not be plugged, is the engine light on, are there any stored codes, any recent work done, I am not sure how it would happen but the Rev limiter setting may have changed and doing this.
Thats just it a plugged cat. is one of the only things that does not always through any code.
2 codes air flow sensor and torque converter circuit open
