Motorcycles Logo
David Myers Posted on Feb 11, 2016
Have 2000 Suzuki 600 Katana no headlight I put in new bulbs and they just went out.
2000 Suzuki Katana GSX 600 F. Does it have a fuel pump please?
Question edited for a lot more clarity, full 'year make model'..
Question moved to model category.
Of course if it is fuel injected, but you are near the crossover year. Do you see carbs?
https://www.google.com/search?q=2000+Suzuki+Katana+600+does+it+have+a+fuel+pump
https://www.motorcyclespecs.co.za/model/suzu/suzuki_gsx600f_katana%2000.htm
I have a 2000 Suzuki Katana 600. Someone stole my flasher/kickstand relay beside my fuse box can I bypass this relay?
No you can't. You will burn out the switches. Just buy a used kickstand relay for $15 and a flasher relay for $8.71. There appears to be two relays, one for flasher and one for relay. When you write 'flasher/kickstand relay', you are indicating one relay does both because of the slash /
https://www.google.com/search?q=2000+Suzuki+Katana+600.+flasher+kickstand+relay
2000 Suzuki GSX 600 F (Katana) how to set the float height
Remove the carbs from the bike, then remove the bottom of the carbs to gain access to the floats. You want to flip the carbs upside down and set them level by bending the tabs.
1helpful
2answers
No working lights on 2000 suzuki gsx 600 katana (electrical)
IF EVERYTHING ELSE IS OK, SOUNDS LIKE YOUR IGNITION SWITCH COULD BE GOING BAD.
I have a 1992 katana 600 runs great but when i reved it up it blew out all the signal bulbs and the headlight any advice would be great thanks greg.
sounds like the regulator/rectifier may be goiing bad. This is the motorcycle equivalent of a cars alternator. have it checked/tested by a professionl or yourself if you know how to do it.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
