Here is a manual for a newer mge model. I don't think your going to find a manual on the older mgb around and they tend to be very similar from one model to another so it should help. Though you should be able to get parts.
http://www.mitsubishi-generators.com/pdf/540811+NM%20Products+MGE1801-2901-4000-4800-5800-6700.pdf As for the gfci brand, I have not had any problems with any of the brands out there. So the cheapest is the best. The 30amp socket could be 110 or 220vac. If there is a selector switch on your machine. If not, there should be a NEMA number on the face of the socket (ie 15-5R). The R stands for receptical while a P stands for plug.
Here is a plug configuratio diagram that will help identify your plug and the voltage it puts out. These are standard so you can be sure that if it the same plug it will put out the same power. Be carefull to ensure which side is larger or has a tab is correct.
http://www.frentzandsons.com/Hardware%20References/plugandreceptacleconfiguratio.htmWhile replacing the plug just swap wire for wire in the same place as your new plug. Gold connector to gold and silver to silver.
The inside of a small generator is very similar and if this don't help I can walk you through any connections you have questions on. Pictures would help if it comes to this.
