Maytag Neptune MAH5500B Front Load Washer Logo
D
Donna Posted on Jan 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wash cycle are running to long
The cycle times have doubled in amount of time. THE Light soil level has gone from 25 minute s to 55
Claude Kayser
Level 3:
Top Expert:
  • Maytag Master 9,098 Answers
  • Posted on Jan 12, 2016
Claude Kayser
Maytag Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067818
Points
28436
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
1helpful
I am trying to clean earthen pottery plates in my dish washer and after washing half of the plates disappear.
The Kenmore PRO also has an Ultra Wash Filtration High Energy Filtration System that helps the majority of us with hard water. It features 2 spray arms, and a Turbozone that blasts away the most gunked up items you can make a mess on.
The Kenmore PRO also features 6 cycles. The High Energy Smart Wash Cycle is the most advanced and versatile. It actually senses the load size, soil amount, toughness of soil and uses minimal water and energy. The Smart Wash Cycle runs from 110 minutes to a max of 194 depending on toughness of soil and uses from 4.2 gallons of water to 6.9.
The Pots Pans Cycle also makes some adjustments depending on soil level and takes from 140 minutes to 203 minutes to complete. It uses 4.8 to 6.9 gallons of water.
There is also a self-adjusting Normal Cycle that runs from 110 minutes to 193 minutes and uses 4.2 gallons to 6.9 gallons of water.
The Kenmore PRO also has a self-adjusting China Gentle Cycle that provides a light wash and gentle dry for delicate items and runs from 105 minutes to 194 minutes and uses 4.2 gallons to 6.9 gallons of water.
It also has a 1 Hour Wash that runs for 58 minutes and uses 8.0 gallons of water and a 15 minute Quick Rinse Cycle that uses 2.1 galllons of water.
The Kenmore PRO also has 5 other options that are additional to the Cycles. Each option adds time and water to the selected cycle. They are:
TurboZone, HI Temp Wash which raises the water temperature to 120 degrees F, a Steam Sanitize which raises the final rinse to 155 degrees F, a Top-Rack Only Option, and a Heated Dry Option.
The Kenmore PRO also has a Delay Option that allows you to run the dishwasher on off-peak hours and delays the start time up to 6 hours.
I have not field-tested all these options yet, becaue I am such a skeptic -- and picky about my dishes, I usually go ahead and always use the TurboZone, the Hi-Temp Wash, the Steam Sanitizer, and the Heated Dry Option. But, hey if you are plunking down $1500 for a dishwasher--you should make use of all your options. I'll keep this review up-to-date as my dates with the Kenmore PRO progress with dinner parties and my very precious china, but for now (mostly because of the "ClangBanger") our good china is safely stored in the cabinets.
The times seem to have changed on the settings for soil levels. For instance, the quick is 50 minutes and the normal is 84 minutes. That does not seem right. Is there any way to set them different?
Answer to your question "Is there any way to set them different?" Short answer is no. The Maytag Neptune like many other washers that display a time of cycle first start with an estimated time this relays a lot on the last cycle ran. But, more importantly it also takes into consideration other washing options. For example, lets say that your quick wash cycle used to only display 35 min. now if you select an extra rinse option the time will increase from that 35 min. to a higher amount of time. This is due to the longer time it takes to go through a second rinse cycle. The MAH5500 if I'm not mistaken also has a heater in it so there are options such as sanitize which takes 120 degree hot incoming water (suggested temp. for hot water heaters) and heats it to approx. 165 degrees. And as you can imagine this takes a washer some time to do this (increasing wash time). If you would like to lower washing time check the washing options and remove any that are not needed at that time; pay close attention to extra rinse cycles and the soil levels that are selected. Hope this helps. Cheers.
2answers
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
1helpful
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
2helpful
2answers
Soil level light cycles by itself.
unplug the machine. take the computer broad out of the control switches. Clean the resadue off both sides of the broad, with a small amount of hydrogen peroxide and a q-tip. Dry it off !!!!! put back to getheir and turn it on. that should fix it!
Incorrect times on wash cycles
you dont need to reset the times, all that has changed is the soil type. in example, light, regular or heavy. that is what causes the times to change.
you just need to push the options button until it shows the type of cycle you want.
also make sure you have the proper cycle selected and then look to see what other options are selected. you just have too many options turned on, so look at the controls to see what is different then you remember.
Wash options
If its working ,DONT FIX IT!  try not to focus on the minutes its taking,and youll be  better off.
2answers
Clean light flashs seven times, stops and then does the same over again.
bellman, on this model I believe you can clear the fault by pressing high temp scrub--air dry--high temp scrub--air dry in that order. Your normal cycle on this dishwasher is approx 97 minutes without the thermal holds, (pauses to heat the water to proper temps.) So of course it's going to go over 97 minutes. This is for heavy soil. Light soil, approx 89 minutes. Some models have a soil sensor, some don't. If the sensor is out of specs..it could add to long wash times. The heater may in fact be the problem, he needs to check it. The heater runs through the nuetral side of the door switch so you want to make sure the switch is closing and the dishwasher is level and secure. He also wants to check out the resistance of the thermistor, should read 48 to 52K ohms at aprox. 75 degrees. Catriver..post back.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
