SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
SOURCE: Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: 5500 generator stopped producing eletric after
First check with the
dealer and see if it is still under warranty. If it is not, make sure nothing
is blocking the air flow around where the control modules are located. This
could cause the voltage regulator and other electronic parts to overheat. Next
check the brushes and make sure they are free of any dust or build up preventing
them from making contact.
If everything is OK the
next thing I would do is change the voltage regulator.
