Richard, could not find your exact model, second link is Rockwell where you can contact them to get a safety manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.facebook.com/803906806364452/videos/821489884606144
Contact Us
http://media.supercheapauto.com.au/sca/files/fact-sheet/7fc52383-a91b-402f-a31f-27ffd7c45837.pdf
Nope cant find one
http://lawnandgarden.manualsonline.com/manuals/device/trimmer.html
is this about a 2011 model
is this a clone of another brand
sold cheap rockwell are about $120
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
SOURCE: operating manual for Honda whipper snipper
If you have the UMK 425 model....
http://campaigns.hondampe.com.au/Power%20Equipment/ownersmanuals/brushcutter/umk425own01.pdf
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
