Sewing Machines Logo
Posted on Dec 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
  • ladybugjfc Dec 15, 2015
    Thank you, I'm looking at the Janome HD3000 as a new addition for leather sewing. I've found only positive reviews.so far.
Michael wade
Level 1:
Habit-Forming:
New Friend:
  • Contributor 6 Answers
  • Posted on Dec 30, 2017
Michael wade
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
6
Questions
0
Helped
1144
Points
18
Not all domestic sewing machines are equipped to handle thick and tough materials. Usually, good machines such as a Janome can handle basic leather projects, so you are understandably concerned about what this sewing machine can handle in terms of leather thickness.
For example, the Janome HD3000 was the number one best-selling sewing machine for leather in 2017 and even though you can use it for leather, it cannot handle thick leather or thick materials very well. However, it does depend on the material and the thickness. You should take the time to read more about sewing with leather on a Janome.
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Dec 13, 2015
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2619140
Points
59176
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
5 Related Answers
lavon82931
La Von Beckstead
  • 17 Answers
  • Posted on Jan 25, 2009
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Anonymous
  • 26 Answers
  • Posted on Aug 22, 2009
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Anonymous
  • 152 Answers
  • Posted on Oct 14, 2009
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Anonymous
  • Posted on Apr 21, 2010
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Anonymous
  • 6 Answers
  • Posted on Dec 21, 2010
SOURCE: Can I use a twin needle on my Janome MW3018?
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
I have a Consew 206rl and it won't sew on double layers of leather but sews fine on single layers. What adjustments can I make
Sewing on double layers of leather can be challenging, and it's important to have the machine properly adjusted to handle the thickness. Here are some adjustments you can try:
  1. Needle size: Make sure you are using the correct needle size for the thickness of your leather. A larger needle may be required to penetrate the layers.
  2. Tension: Adjust the tension of the upper thread. If the tension is too tight, it can cause the needle to break or skip stitches. If it's too loose, the stitches may be uneven.
  3. Presser foot pressure: You mentioned you have already adjusted the presser foot pressure, but to clarify, turning the adjustment screw clockwise will increase the pressure, while turning it counterclockwise will decrease it. You may need to increase the pressure for thicker materials.
  4. Stitch length: Increase the stitch length for thicker materials. A shorter stitch length can cause the machine to struggle to sew through the layers.
  5. Speed: Slow down the speed of the machine when sewing on thicker materials. This will help the machine to handle the thickness and prevent skipped stitches or broken needles.
If none of these adjustments work, you may need to take the machine to a professional for further inspection and repairs.
I have a janome 10001 and blue tip needles do i need longer needles for towels?
Generally, your machine takes only one length of needle--the one specifically for your machine. Using a longer needle will cause the needle to hit machine parts that it should not--possibly causing broken needle parts to fly anywhere, including in your face. Just because you are sewing thicker fabric, you shouldn't use longer needles. If the fabric is too thick to fit in your sewing machine, then you should not be using that machine to sew the fabric.
1helpful
Can you sew leather with the Hobbylock 786? Also is a price of $190 good for this machine? Thank you
Difficult to say since we don't know anything about the leather. Generally, a soft, thin leather can be sewn on a domestic machine. However, a thick leather will cause problems. A domestic machine does not do well stitching thick leathers/fabrics. Usually, leather stitching will require a heavier needle, ie a leather/denim needle, which is a size 16. Frequently, manufacturer recommendations limit serger needles to no larger than a 90/12 needle. Using a needle that is too large could strike resulting in broken parts or knocking the machine out of time. Also, sewing thick fabrics places undue stress on the machine. It can cause gears to break or the motor to overheat and burn out. Be aware that a serger trims the fabric as it stitches, so there could be issues with the knives trying to cut the leather.
Guess I am somewhat confused why you would want to use a serger to stitch leather. Normally, a sewing machine that stitches one single line of thread is sufficient for leather. Overlocking uses multiple threads which increases the thickness of the seam.
1helpful
I have a Singer sewing machine#7258 what setting and needle and thread do I use to sew leather
Hope it is light weight leather. It should not be used on heavy leather.
Use a brand new heavy needle (leather). Avoid using upholstery or thicker thread as that sometimes does not feed well through the needle eye. Set it for a longer stitch. And you might want to adjust the presser foot pressure to accommodate the thicker fabric under the presser foot. Also, a leather foot, roller foot, or walking foot may be helpful--if if not available, try using parchment paper (or something similar) on the surface of the leather to help it slide under the presser foot..
1helpful
Is a dressmaker 300z able to sew heavy material like leather
Depends how thick the material is. Most mechanical machines will sew thicker fabrics, however, if the needle is unable to penetrate the fabric, it could damage the machine. Be sure to use a heavier, sharp needle.
What type of bobbin should I use in my Memorycraft 4000.. Plastic or metal..I have been using metal, is this ok?
You should be using plastic bobbins for the MC4000, see: http://content.janome.com/index.cfm/Machines/Accessories/All/Bobbin_-_Plastic . Usually the machine comes with a handful of the correct size and type bobbins. Using the wrong bobbin could result in the needle hitting the bobbin and damage may occur. (Broken needles are the most likely possibility; damage to the bobbin case or timing could occur and would require the machine be serviced.)
When you buy more bobbins, make sure that they are labeled for Janome or a machine that takes the same size bobbin. See this site for a list of machines that also take this size bobbin: http://www.sewingmachinesplus.com/102261103%20-20pk.php
I hope this helps.
Hi Can I sew plastic on 25 y.o. janome machine.
Plastic is easy to work on. Any needle will work, I'd go with a sharp not ball point. The stitch length should be a bit longer so you won't have the perforated effect and cut through the plastic. A thin size thread will cut the plastic vs a thicker one. Always try a sample first so you can adjust the tension specially if you can adjust it from the bobbin. GL
I need a new Motherboard for my MC4000. Where can I find one?
Try here, https://www.sewingpartsonline.com/janome-mc4000-sewing-machine-parts.aspx or try Janome them self .
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
