Timex 1440 sports watch - the digital display is not working correctly (for example 20:00 looks like 10:00, because the far left of the digital display doesn't show anything). I tried replacing the battery and pressing on the digital display to no avail, Any magic fixes? Or do I just need to buy a new watch?
mcdevito75 here, For now, you need to know 2 buttons, the MODE and SET buttons, First press the MODE button, you may have to hold it in 2--3 seconds, see the display Blinking, now press the SET button for each function, (hour, minute etc). press MODE after each function is set, after all is set Press MODE for steady display. Here"s Timex Contact number for a manual, 800-448-4639
To set the right date on your timex, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
My son's watch (WR 50M) broke... so I have a strap, if you'd like it. He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh? If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
Setting My Timex 1440 Sports Watch
(4-button) 1. With the time and date showing, press
the top left button. 2. Press the right top button (this sets
seconds) 3. Press the bottom left button. This flashes the
symbol for am, pm will show if pm). 4. Press the bottom left
button, minutes flash. Press the top right button until correct minutes. 5. Press the bottom left button, month flashes. Press the top
right button until correct. 6. Press bottom left button, date
flashes. Press the top right button until correct. 7. Press
bottom left button, day flashes. Press right top button until correct. 8. Press bottom left button, time format flashes ( now it can be set to
Timex Digital Watch
