This Maytag Maxima XL will not go into the spin and drain cycle after 13-19 minutes washing a bathroom rug. What cycle to use?
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
SOURCE: Maytag PAV2000
No. Just means your problem is a little worse than you thought.
Still, the brakes are the culprit
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
SOURCE: maytag washer will not agitate during wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Above is a service manual this will show you how to troubleshoot and repair.
SOURCE: MY MAYTAG MTW5800TW TOP LOAD WASHER WILL NOT GO
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
