ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
Fuel value under fuel tank, tried to turn on and the **** broke and no fuel will come thru even when I use pliers. It may be broken inside, looking for replacement
Re: ETQ generator DG4LE cut off value under tank broke...
Syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Probable cause would be a carburetor that is over-filling, Possibly from a sticking float, or an over-pressurized fuel tank.
Make sure that the vent on your fuel tank is working properly, and remove the bowl from the carburetor to make sure that the float moves up and down freely.
is gas line broke or disconnected? Either way it has to be reinstalled.First, get new gas line, and be sure to get it longer then you need, because, you will need to cut a sharp angle on one end then install this end into gas tank, then reach thru gas cap opening with needle nose pliers, get ahold of fuel line and pull thru. if you do not cut angle on new fuel line, you will never get the line into gas tank.
Take your old line to a lawn mower parts store, ask for a new gas line of the same size. I would buy about a foot long. Push the line in the tank down into the tank(doing this with the tank empty), remove gas cap, turn upside down, a filter and your old line will fall out. Press the new gas line through the hole, push enough through that it comes out of the filler hole, place filter onto the new line, drop into tank, cut off excess and reattach to the carburator.
