The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. There is a small clear plastic hose that attaches to the pressure switch that senses the pressure change from the wash tub as the washer fills. This change in pressure is what will determine when the pressure switch turns off.
Commonly, what happens is the hose becomes detached inside the console causing the pressure switch to not work. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Before assuming the pressure switch to be faulty, follow the advice in the link provided. What appears to be a significant problem, may just be something as simple as a loose hose. Make sure you check the entire length of the hose for cracks or leaks.
Check the electrical connections on the switch as well to make sure they are not corroded, causing no contact.
If all else fails, replace the pressure switch. Replacements can be found at appliancepartspros.com for about $21. Locate item 12 under Section 4 (Controls and Rear Panel Parts).
If you have questions, please let me know. I hope you find this information helpful.
