SOURCE: Front fork oil capacity
Hi Lukepentcof.
its 350cc or 11.8 ounces in the Clyma book, but that's for a 1986 onwards model. you can vary the amount you use to suit your style of riding anyways. I doubt it would be that far from the mark.
regards
robotek
SOURCE: Fork Oil Capacity
Use Yamaha suspension oil #01. Amount is 19 ounces. Oil level from top surface w/o cap nut is 3.15" to 5.51". I am sending you a link to a site where you can download a free shop repair manual. It is actually a bit complicated as you will see in the manual.
http://www.carlsalter.com/motorcycle-manuals.asp
Top rating due on this one! Thanks!
SOURCE: 97 yamaha thunderace fork oil capacity
270mls per leg, or 280 if you want a little stiffer ride
SOURCE: Fork oil capacity for a 2005 kawasaki vn1600 mean
Hi Des, Im am Irish too, howya doin? The oil you want is SAE 10W-20. and 445ml if you are changing the oil. It can be more accurately checked with the fork removed and fully compressed and the spring removed, the oil will be 120mm from the top ot the stanchion.
The manual will give you more info on this and any other future problems so here is a link to it. Good luck to ya, and please rate me if I've helped you. Thanks
[email protected]
VN1600 manual...
http://www.scribd.com/doc/9607829/Kawasaki-VN1600-A1A2-Vulcan-03-Service-Manual-ENG-by-MosuenoPW
