I rebuilt the zama carb but it will not run for more than 30 or 40 seconds what did i do wrong
There are plenty of things you may have inadvertently done wrong, start first by checking fuel to the carb, replace the fuel filter in the tank, check the fuek hose up to the carb for signs of leaks, if all ok, re check the carb, on the pump side it is very importent the diaphram goes against the carb body followed by the gasket and the cover, this is because there will be two small flaps on the diaphram that act as non return valves, so must be against the carb body, there will also be a filter under the diaphram, this should be replaced, on the metering side of the carb it is very importent that the gasket goes against the carb body followed by the diaphram and cover, this is because the gasket is used as a spacer if not there the diaphram will be too close to the metering lever and it will flood, under the diaphram will be the metering lever, needle and spring, make sure this all moves smoothly, the metering lever should be level with the sides of the carb body, there will also be core plugs pressed into the base of the carb, these will be covering the jet holes, dirt can accumalate under these, however you need to pearce the plugs to remove them, and replace with new.
Hi Richard Formo, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the carburetor make and model number. This found on the carburetor itself.
Also it is the metering diaphragm you referring to then gasket goes next to carburetor main body and the diaphragm with the large disc facing the carburetor body. Most this diaphragm will only go one way.
