You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sony Corporation
Rating: 4.1 - 9 reviews - $249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
you can connect two diffent ways with your bravia lcd tv one is videu out connection from dvd &put the cable in to video in to tv other way is rgb connection there is three color sockets in your dvd player & same as your lcd tv so connect with color wise & switch tv to component
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector
2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
