LE error code means LEaking! It means that some water has gotten down into the base of the dishwasher. Usually the most common sources are a bad/leaking drain pump, or a leak in the drain hose. Could also have a clogged or partially cloggeddrain hose, causing the water level to get too high and overflow. Too much suds can also cause a leak.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
An LE error code means problems with the motor. It can either be load issues, excessive suds, thermal overload protection, or a new installation. To solve this motor problem, you must first uncover the underlying cause.
