I think its the final spin cycle that doesn't work. It does everything else fine. Sometimes if we cancel it and restart it it works.
Kenmore 110 4996 Use And Care Manual Troubleshooting
Testimonial: "Amazing. it worked. I was afraid I was going to have to replace the circuit board or some other expensive part. thank you."
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Chances are the Drive Motor is at fault and may need to be replaced
