Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
