Cricut Expression Cutting Machine Logo
C
Carmen Hernandez Posted on Nov 05, 2014
Why my display window does not light up ? - Cricut Expression Cutting Machine
liam ostrander
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 05, 2014
liam ostrander
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
964
Points
9
Black screen with power lites on?cq61-313us notebook
Most likely failed back lights in the laptop display.
Can you see your windows screen if you look at an angle.
If you connect an external display, does the external display now work. External displays can be VGA, HDMI, Display port, DVI and the newest would be USB-C.
Any external display that you can connect to confirm the video isn't bad and that your back lights are dead.
Have a great day - Hope this helps
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
After disconnect and reconnect the battery of my opel antara, the indication of odometer displays only 888... for all indications. How can i reset it?
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
1helpful
My nissan Almera S reg has no side lights or dash lights.All fuses seem ok.
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Changing dashboard light
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
4helpful
4answers
No display on screen but lights on keyboard. The battery and power lights come on and the hard disk light blinks, but there is no display on the screen
Try an external monitor on the laptops vga output, if the external monitor works ok then you have either a faulty screen or inverter
1helpful
How do reset emission light on vw golf 1.4 petrol
If you mean the service light here is the procedure.
Button #1 mileage reset button
Button #2 Clock adjustment button
  • Switch ignition off
  • Press and hold button #1 at bottom left of speedometer
  • Switch ignition on and release button
  • The text "service Oil or service INSP" will appear in the display window. On 2000 m, y, cars the message "SERVICE NOW" will appear in the instrument cluster with center display
  • Turn button # 2 at lower side of tachometer to the right
  • The service display shown in the display window is now reset and "service _ _ _" will appear in the display window
  • Switch ignition off, service display is now set until next scheduled service interval is reached.
3helpful
Display colors too light to see
Go to control panel---->Display------>check if the display is nVedia or Intel. Accordingly follow the steps and use the best, with color depth enhancement set the display for your type of monitor to achieve the and also check if Icons have 100% opacity and not translucent ....sodeep
Display
Yor LCD screen may need to be replaced.
Top Cricut Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
