To clean the carbureted model's filter, you drain the gas from the tank, remove petcock and filter, clean filter with compressed air, reinstall. The fuel injected model requires that you drain the tank, remove the entire pump assembly from inside the tank, and then replace the filter (it can't be cleaned).
The carbureted model's filter is supposed to be inspected and cleaned every 20k miles. The fuel injected model's filter is supposed to be replaced every 25k miles.
SOURCE: fuel pump?
the fuel pump for your 2000 fuel injected road king is located in the fuel tank. you will have to remove the speedometer housing, by first removing the seat, then remove the one small screw near the seat that holds the speedometer housing in place, also remove the small screw at the front of the speedometer housing and lift the housing off the tank and disconnect the wiring that goes to the back of the speedometer. there is a large oval shaped gold in appearance plate on top of the fuel tank. this plate is what the fuel pump is mounted to.
SOURCE: location of the fuel filter
fuel filter is located in the fuel tank at the end of the fuel pump
SOURCE: how to replace fuel filter on harley davidson 02
I am having problems viewing the reply but if you have a FLHRCI then to replace the fuel filter you will need to be prepared to put some time into it.
First remove the console off the fuel tank, one nut below speedo and the phillips screw lower close to the seat. You will have a disconnect on the top left side of the fuel tank to disconnect. Then disconnect the vent tube from the tank with a gentle pull & twisting motion. Now the fun part there are ten torx T20 screws you need to remove, but first you must go buy new ones along with the gasket and fuel filter kit. DO NOT reuse the screws. Now for whatever reason they call this piece a canopy, go figure. Once you have your parts go ahead and raise the canopy slightly and twist it to the left a little. Now this can be tricky because there is a spring loaded hng to work here, be care not to over stress any thing. Then you can begin to pull the canopy and components from the tank. You will be limited by the convoluted tubes (hose) attached as to how far you can raise the canopy, if you remove one be careful as where they attach is plastic and breaks....easily sometimes, then you need a $350 part.
Next read and look at the diagrams that come with your new fuel filter to install it. Once done carefully reverse the canopy removal process and tighten the canopy bolts in cross pattern o somewhere between 18-27 in-lbs. Hope this helps.
JP
SOURCE: picture wiring diagram for 2003 harley fatboy
May I suggest a trip to your local library. Cycle repair books should be in 646 stacks of reference.
Otherwise you can Google for 2003 Clymer Service manuals on the internet.
I think Clymer had electrical diagrams in their books. I doubt that any except the HD service book would have anything about the physical location of the harness, but the pictures in the other books would help you.
SOURCE: engine diagram for 88 cubic inch harley davidson
I was able to pull up the complete maintainence book with wiring diagram, parts assembly, torque specs and part numbers by just going to www.1972 flh 80 harley davidson oem.com
