Life Fitness 9500HR Treadmill Remanufactured Logo
A
Anonymous Posted on Aug 20, 2014
How to replace walking belt ?
Start to finish replacement of walking belt
Sportsmith LLC
Level 3:
  • Life Fitness Master 920 Answers
  • Posted on Jun 09, 2015
Sportsmith LLC
Life Fitness Master
Level 3:
Answers
920
Questions
0
Helped
514851
Points
111994
Although a different machine, the processes are similar. Just be sure to accommodate to your hardware. I will be including a link to your manual also.
Link to manual;
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/Tr9500/9500%20Treadmill%20Manuals/Operation/m05100k26a200%20Classic%2095HR%20Treadmill%20Operation.pdf
Link to Video on how to replace deck and belt;
http://www.sportsmith.net/video-player.aspx?did=36339058-8E69-402F-A2E8-182887979B5C
My incline stopped working a few weeks ago. Now I have another problem, I turn it on and the belt starts then stops.
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
The belt has been replaced and is slipping
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
1helpful
The belt is sliping as I walk or run
Belt skips when weight goes on. It squeaks and
My Proform 695 LT runs fine when Iam not on it but when I get on the machine it starts pausing in between running or even a slow walk
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
1helpful
Reebok treadmill
Hi James
1helpful
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
1helpful
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
1helpful
Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
