I don't see an Output Switch on the panel...any other suggestions. There's a plug in the back of the panel and I have made sure it was plugged all the way in. I also opened the panel box but did not see any ON/OFF switch. There are reset buttons on the front of the panel, but they are both pressed in. When I have had an overload in the past, these I have reset and the plugs worked fine.
ProHydroRace,
I did not see an on/off switch. I also opened up the panel and did not see one there either. There are reset buttons on the front panel and I have had to use these to reset before. Any other suggestions?ProHydroRace,
You can't post conmments that contain an email address.
there are two things in generator out put one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
ProHydroRace,
ProHydroRace,
