Maybe you can get some help for troubleshooting generator from this article. Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Not normally, the board outputs to the fuel pump, or LP shut off solenoid. It doesn't know the difference.
SOURCE: Why will my generator start but shuts down when start button is released?
Power to the motor switching off to ignition system check wording is correct.
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
