No error code displayed
SOURCE: PC board of Lavamat 42260 Top Loader washing
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
SOURCE: washing machine - efo error display. machine
The code EFO shown to the user can either be related to a blockage in the filter or pump.Also check the outlet drain hose for kinks or blockages.Another one to check out is that there is not too much detergent in the drum as this causes overfoaming.
Hope this was helpful.
SOURCE: washing machine lavamat 74810
EFO error is a water leakage error.You need to call for service.
Thank you
SOURCE: Washing machine gets stuck mid cycle and doesn't
mine to try clicking one notch more the control button I posted a question to know what parts to replace . I think the dail may be wrong.
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
