AEG Lavamat 72640 Front Load Washer Logo
A
Anonymous Posted on Aug 03, 2014
How to reset - AEG Lavamat 72640 Front Load Washer
tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
7helpful
2answers
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
