My recently installed pioneer deh-x4600bt no longer shows Bluetooth as a source option (only radio and aux). I have been using Bluetooth to play music from my phone but suddenly it's no longer available as a source.
Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Is bluetooth on at your phone? Pair your phone again with unit, refer manual page 11.
SOURCE: I can't select aux when I plug my ipod into my Pioneer stereo.
I think this can be done with the stereo on but you have to hold down either the e button or 1 of the buttons on the right side of face(not audio)maybe and a menu will pop up and you should run into a screen that ask off on or off you will want it on and then you should be able to access ur ipod by pressing the source button.Hope this helps.
SOURCE: i have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
SOURCE: Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
