The indicators light up and the wash time displays, but as soon as i take my finger off the button it all goes out. If I hold my finger on the normal wash button throughout the entire wash/rinse/spin cycles (45 minutes) the washer will work, but as soon as I take my finger off the button the machine shuts down.I am not getting any errors on the display
This is just a guess, but the button should latch up when depressed. It could be mechanical (replace the button) or electronic replace a circuit board.
Hello Lynn Wendell,
Most likely you have a control board issue...
I have returned a long way ...
So this is a serious departure...
Have your model number ready
and get online with searspartsdirect...
Water Filters Lawn Garden Appliance Parts
(Quote cost) and get your absolute part number...!!
Compare that cost at appliance parts
Search Over 2 1 Million Appliance Parts
BETTER STILL.. compare THEIR PRICE
and look for their FREE video guide.
Hopes this helps
Carnac the Magnificent
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
SOURCE: kenmore he2 front loader washer won't do rinse spin cycle
kappharmd-
if yours is the same, the drain is hidden behind the lower access panel on the front (how convenient, huh?). I don't understand why they didn't just make a recess hole for it. I've just left one screw loose in the center and it kinda "compression" fits. We clean this out regularly, as my wife and family don't check pockets well. :)
SOURCE: Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front
panel under the washer door. Your filter door will be light brown. If
you find
a hose there it is to drain out excess water (water that could not be
drained
by your pump) After you have drained, unscrew the cap and remove all the
junk
inside. Have a large plastic bag to catch junk and water. Refit
carefully after
cleaning out. If not solved, something shd be blocking your pump, check
this
out. F-21 filter blocked.
How abt a nice rating for the free
help?
