Error 91-125 on a Beta SP UVW 1800 is a diagnostic code indicating a problem with the audio channel 1 input. The error message "appears like a feedback on audio channel 1" suggests that there is a signal present on audio channel 1 even though nothing is connected to it. This could be caused by a malfunctioning input or a problem with the internal signal routing.
Here are some steps you can try to troubleshoot this issue:
Check all audio inputs and outputs to ensure that nothing is connected to audio channel 1.
Disconnect all cables from the Beta SP UVW 1800 and power it off. Wait for a few minutes and then power it back on.
Check the audio routing settings in the menu of the Beta SP UVW 1800 to ensure that audio channel 1 is not being routed to an unexpected location.
Inspect the audio channel 1 input for any damage or corrosion.
Try a different audio cable or input device to rule out any issues with the current cable or device.
Check the manual of the Beta SP UVW 1800 for any specific troubleshooting steps.
If none of the above steps resolve the issue, it may be a hardware issue and you may need to contact the manufacturer for further assistance. It could be a malfunction in the audio channel 1 input circuit or a problem with the internal signal routing. A qualified technician should be able to diagnose and repair the problem.
I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS.
(Look for clogged hoses, in and out!)
Sadly it only lists three 'error codes' on Page 27 and they include:
E10 E21 E31
Summit SPWD2201SS Washer download instruction manual pdf
That is a memory error. Remove and reseat the memory in your computer. If the error persists and you have more than 1 stick, try each stick separately to find the faulty unit. If you only have one stick, then the memory will need to be replaced.
