For removing/replacing the deck belt, the general method is:
- turn off engine, remove key and set parking brake
- disengage blade by putting blade engage lever into off (disengaged) position
- lower the cutting deck to the lowest position (closest to the ground)
- relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
- remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck,
http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams,
http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an
Authorized Toro Service Dealer to have your drive belt replaced.
