Onan Marquis Gold Quiet Gas Generator 5500 Watt by Cummins Onan Logo
A
Anonymous Posted on Jun 10, 2014
Onan marquis gold gas generator 5500 stops running after 5 minutes
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Onan Expert 573 Answers
  • Posted on Feb 19, 2015
Renee F
Onan Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248134
Points
680
Check fuel pump pressure, how long has it sat. What load is on after it stops?
2answers
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Onao generator fuel pump loses power
Is it losing Battery power, or just not pumping? check connections, and pins on board connector. Failing that replace the board, if Battery voltage is been lost
2answers
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Doesnt want to start, when it does it runs rough then dies, several tries and it will run rough and eventually smooth out and run ok, also intermittant loud clicking sound,think its the fuel pump
sounds like u need a new fuel pump when u first start up fuel has seaped back to tank only when u crank it brings fuel back up then the speed keeps fuel ok , replce fuel pump shud b ok then.
Free Service Manuals
What is the question? You want a free service manual?
5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Top Onan Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
