SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
