EFO = Filter Blocked (low flow) and it is accessible from the bottom front of themachine. 1. there is a blockage in the filter or drain hose.takes too long to drain out.
EFO or EF0, indicates a problem with the detergent - either you're using too much, or you're not using HE detergent, which is meant for most front loaders.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was
not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Hello,the EFO code is a general error that is caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear
it run the machine through a quick cycle or normal cycle but without
using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear
it you can remove the back cover of the pump an remove the hose.
Inspect them and clean them if nay obstruction.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out. 2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle. You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
JK, if your model number starts with 253. this is your ice-bin. Part number 240385201. You can order it at http://www.repairclinic.com/0081.asp?RccPartID=891419
If your model does not start with 253, you'll need to post the complete model number...Catriver..post back.
