Remove the graphic card. Clean the contact points with a piece of clean white paper plus the ram on it. Replace & if possible reinstall the graphics card driver again.
Yes, your Asus motherboard will support the Nvidia GeForce 8600 PCI-Express graphics card. However one thing you should consider. The 8600 card is SLI compatible but the motherboard only has one PCI-E x16 slot. You will also need to make some changes in your bios. In order to help you configure your system for a PCI-E graphics follow these steps. 1. Uninstall your current display driver software through windows control panel. Windows may ask you to restart your system, do not restart. Shut windows down which will shut off the system. 2. Unplug the power cable from the system & open your case. 3. Install your 8600 card. (Double check it is installed correctly & if needed has the extra power cord connected to the card. 4. Re-connect the power cord. 5. During boot up enter the bios by pressing the Delete key every couple seconds. 6. Once in the bios click the Advanced tab, see top of page 2-19 in your manual. 7. Than open Onboard Device Configuration Open North Bridge Configuration, see page 2-22 Change Primary Graphics Adapter to [PCI-E] Change Internal VGA to [Disable] Change Share Memory Size to [Disable] 8. Save Bios changes & exit. Your system will auto restart. Once windows has finished loading install the 8600 driver software & directX 10.0. You can also go to nVidia & download the latest software driver @ http://www.nvidia.com/Download/index.aspx?lang=en-us
Unless you can see the little safe mode text in all 4 corners then it sounds like the computer IS in regular windows, but the video card drivers are gone. Try re-installing the video card drivers from Dell for that particular video card (there are several possibilities) and see if that helps. It is possible the video card is going bad, but usually re-installing the video drivers works. This could be a sign of other problems too- start with the video drivers and see if that helps. If it does not- I'm guessing the operating system is corrupt, virused, or the video card is going bad.
