The soap compartment has water left in it - LG 14-inch Front Load Washer/ Dryer Top Mount Pedestal Refurbished 14" Laundry Pedestal Plus Storage Drawer in White
Does the unit work? if so, dun worry about the water. unless the soap has not been gone into the wash?? do not use powder! these are liquid soap washers! lol.
Usually means soap dispensing drawer needs to be cleaned, as conditioner is dispensed by syphoning system, Take out soap detergent drawer, clean thoroughly in warm water, make sure drain hole in conditioner compartment is clear.
Hi, The soap dispenser may not be the problem. It could be that it's not getting enough water. Is the pump running and water cleaning the dishes. Then there is no problem.
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
check the top of the cabinet after the unit has started to wash the water droplets is the key. if you see water droplets on the very top all over then the unit circulation pump is working. If that checks out then check the jet dry compartment. here is a trick.
open the compartment door, fill compartment until it cant hold anymore liquid,close compartment door,lower and raise the door 3 times,open compartment door check to see if you fill with more jet dry,repeat this process untill it cant take anymore.
what this does is removes the air out of the compartment. this will last for about 10-12 washes. last thing is to turn your faucet water on until it is the hottest then start your machine. use cascade soap and no tablets. when you use tabletrs with jet dry the machine over suds, the rinse aid compartment or dispenser is vidal to drying,cleaning spots and film. hope this helps.
Miele novatronic w864 washing machine.This video will show
you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073 Where do i put the soap? Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in? Do i mix the soap in with the water in this compartment or is there another location where i add the soap.. We have looked the machine over and see no other place to really put the soap... will it ruin the machine if we just add the soap with the water in the detachable compartment?
Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.bissell.com/By Phone Customer Service: (800) 237-7691 Hours: M-F 8:00 a.m. - 10:00 p.m. ET Saturday 9:00 a.m. - 8:00 p.m. ET Don – The Vac Man Go Ahead.Use Us.
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
