What does EFO mean
Its an anti flood warning. generally it means something has leaked into the cabinet and water has triggered the safety float on the floor of the cabinet. You will probably find a small leak somewhere which has allowed water to gather under the machine. IE/ Hose, front gasket, pump etc.. If you tip the machine backwards to drain all the water out of the base, it will probably work until the safety switch triggers again. Locate and fix the leak before it gets worse and causes some damage.
