Hi! My G2 is originally set on japanese language, i tried to change it, but the option is not exist. How can i solv this problem?
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
SOURCE: Operating Instruction Manual NEEDED for Panasonic Lumix DMC-FX40
Press [MENU/SET], select the [SETUP] menu with wrench icon then select the talking guy icon, select English then [MENU/SET].
SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
SOURCE: hi i have the panasonic lumix dmc fx37 and the
Turn the camera on. Slide the REC/PLAYBACK switch to REC (camera icon). Set the mode dial to the camera icon. Press MENU/SET to display the menu. Press Left-arrow. Use the Down-arrow to navigate to the wrench icon. Press Right-arrow to select the Setup menu. Navigate down to the icon of a face in profile with a speech balloon. Select that, then select English.
SOURCE: language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
I do the factory reset, but the option is also not exist and i have only 4 pages on the setup menu.
is there a talking head icon in the setup menu>
no, there isn't. this is the problem, but may i cant solv the problem with a hack tool. because there isn't language menu in japan version
